Thermaltake DH 104
Bundle & Internals
Published: 27th November 2008 | Source: Thermaltake | Price: TBC |
Bundle & Internals
As expected, the bundle with the DH 104 looks fairly impressive. However, whilst it may look like you get a lot more than you would with a normal case, all of the bundled kit is pretty essential for a HTPC.
Going from left to right, top to bottom we have: the user guide/manual, Screws/Stand-offs for installation, 5.25" Drive Bay Adapter, Software Installation CD, Batteries and a Remote. As you can see, the remote has quite a range of buttons, all for various functions, which should be very useful.
Unlike a lot of HTPC chassis, the DH 104 has a full ATX interior. This means you can use pretty much any system you want inside the case, apart from E-ATX or extra large motherboards like Asus's new Rampage II. However, building something of that caliber in something so small would be pretty moronic. At the front you have all the drive mounts, with room for three 5.25" drives, although only one is accessible from outside the case. Round the back we have the 120mm fan, PSU slot/hole, PCI slots, and the external VGA pass-through for the touch screen.
On the left we have the PSU 'bay'. Thermaltake have sensibly padded this out with foam, which will reduce the amount of vibrations coming from the PSU reaching the case. Then on the right we have the back of the front panel buttons. They restrict some room on the 5.25" bays below the top bay. However, as these aren't accessible from the front anyway, their uses are limited.
Above we have the HDD cage and connector cables. The hard drive cage can take up to 5 hard disks, and once again measures have been taken to reduce vibrations. The rubber grommets should mean the hard drives are much quieter, and special screws are provided for attaching hard drives to them. On the right we have all the motherboard connection leads, which include a PSU jump cable for remote power-ons and a USB connection for the front panel.
Originally Posted by name='ionicle'
very nice looking case i must say
but £300 ...phew...bit much aint it 200 would be a better price point for it especially in this credit crunch, people want cheep and cheerful |
Great review, I love these cases - always scared at the price >.<
A possible switch-out of the lcd for maybe a hdd bay or these days.. optional iPod dock ?, perhaps 5.25 opening.. basically LCD or utility opening for added extras u can purchase to suite ur needs. Or ofc blank blate (same color [see below], with Thermaltake watermarked on it - not too heavy to be tacky tho)
Under £200, the unit should sell well, with an obvious after purchase of LCD or any of the above options, would be good business.
The look is very nice imo. It's a shame the flap for the usb/ports looks off-colored to the rest of the unit, it could be the lighting or photography that may make it look worse than it actually is. If that was a spot-on match, I`d class it as slick. For this reason, I'd be more inclined to hunt for a black model.
Nice.Quote
Nice.Quote
Cheers for the feedback!
I agree on the removal of LCD and possibility of other accesoiries, that would certainly be useful..
The USB ports were a slight darker tinge, but it looks great for real, pictures cant do it justice!Quote
anyone aware of other reviews for this case? I miss info on screen resolution. Could it handle 1080p in clone with a HDTV. What cable connection is used for the LCD, VGA?Quote
especially in this credit crunch, people want cheep and cheerfulQuote
