Thermaltake Frio Review
Introductions can be very hard to write, and it doesn't get easier with a well known company like Thermaltake. If anything it's harder because your audience pretty much know it all anyways, so I'll save some time and fill some real estate with a copy and paste from their website.
Since the beginning of Thermaltake in 1999, it has been at the forefront of creating new and exciting products at a time where most computer users were provided little to no choices for components that may seem irrelevant, but in reality crucial to the performance of a PC.
Thermaltake Server Series solutions, with years of thermal experience and industry leadership, sets its goal on reforming total thermal management in server segment by formulating the perfect mixture of versatility, efficiency and thermal management with each respective server product category: Rackmount Chassis, Server Fixed & Redundant Power Supply and Server CPU Cooling Management Solutions.
With its comprehensive line of products available, it enables Thermaltake's core customers to enjoy a one-stop-shop experience, reduce product design-in evaluation period and most important of all, flawless integration process. Each of Thermaltake's strengths enables its customer to focus on their core business while taking advantage of the skills and efficiency of a single thermal management solution partner.
On the menu today is their latest CPU heat sink the Frio, labelled as a cooler for overclockers in our eyes it has a lot to live up to, lets glance over the paper statistics.
Heatsink Dimension
139(L) x 98(W) x 165(H) mm
Heatsink Material   Aluminum Fins
Aluminum & Copper Base
Heatpipe   Ø 8mm x 5
Fan Dimension   120(L) x 120(H) x 25(W) mm
Fan Speed   1,200 ~ 2,500 RPM
Bearing Type   ----
Noise Level   20 ~ 43 dBA
Max. Air Flow   101.6 CFM
Max. Air Pressure   4.2 mmH2O
LED Fan   ----
Power Connector   3 Pin
Rated Voltage   12 V
Started Voltage   6 V
Rated Current   0.5 A
Power Input   6 W
MTBF   50,000 Hrs @ 40℃
Weight   1,042 g
Enough with the delays, let's move on and give this new cooler a look.
«Prev 1 2 3 4 Next»
18-05-2010, 19:37:55
AMDFTW
shame it doesent perform very well,just wondering how much heat does the i7 chip produce over the phenom 2 as ive heard the phenoms have a lower temp when vs the i7'sQuote
18-05-2010, 19:55:48
tinytomlogan
I still wouldnt buy it though. Why would you want to when there are better performing sinks for the same money?Quote
18-05-2010, 20:01:54
ppuff
Looks hot! Too bad it keeps your chip hot though Quote
18-05-2010, 20:45:13
hadesan
I thought aluminum and copper reacted to each other over time...Quote
18-05-2010, 20:55:08
tinytomlogan
Really needs water to make it bad dudeQuote
