Thermaltake Spedo Advance Chassis
Packaging and Contents
Published: 17th September 2008 | Source: Thermaltake | Price: £130.39 |
Originally Posted by Diablo
I have concerns over the screwless expansion card connectors and the use of plastic. Another thing I dislike is the placement of the PSU and the use of louvres not of mesh.
I'm not fussed by the squares personally. But considering that you can see into the back of the motherboard tray via the side panel, they sort of become a necessity. As for the thumbscrews, I really like the ones on the Spedo as opposed to those on the Xaser VII like the idea of the plastic squares on the back of the mobo, but at the end day it is only wire you are covering up. I also notice they've changed the thumbscrews on the back of the case...the worst feature of the Xaser VI
Originally Posted by name='Robert'
the xaser and the armor+ are still the best made thermaltake cases out there to my opinion.
Thanks for the feedback too guys - tis muchly appreciated
the xaser and the armor+ are still the best made thermaltake cases out there to my opinion. and these 2 are in par with cooler master cases to, wich is good. but it is true that lian li is still be best branch for cases, becouse of the finishes they have on their cases, but it also comes with a big price ofcource.
Just wonderidng, does thev case have a removable mobo tray...that was an excellent thing on the xaser that cut down RMA stripping time by about an hour
That's good news about the screwless holders, on the Xaser, I just stripped them off because they didn't work with the 280GTXs or the DX2...bit of a pain. Also the screwless 5.25 won't fit shorter (without 2 screw holes) components like the Pico ITx or most fan controllersQuote
However the case leaves a bit to be desired by the look of it. The Thermal areas thing clearly doesn't work and 50 something decibels is really obnoxiously loud. The looks are fairly subjective so I won't comment, aside from saying it has quite a nice industrial look (from the pics...maybe not in the flesh).
Speaking from experience with Thermaltake cases, they are not as bad as they used to be and while they lack the finish of Lian li, they aren't as bad as everyone says. Still wouldn't buy this one though.Quote
