Xigmatek Prime Review
Published: 30th January 2012 | Source: Xigmatek | Price: £39.99 |
It's fair to say that Xigmatek are perhaps better known for their range of cases than their range of CPU coolers. But lets not think that because of this they don't know what they're doing. The Prime, or to give it it's "Sunday" Name the Prime SD1484 appears to have all the right ingredients to make it a good if not great mid range/enthusiast cooler.
4x8mm heatpipes -check.
Direct contact heat-pipes - check.
Tower type design - check
2x140mm fans - check.
However anyone who's ever baked a cake from a recipe will tell you, it's one thing to have all the right ingredients, but it's another thing to be able to put them together properly and finish up with something edible. For a better look at the full list of ingredients please see the Technical specification below.
Manufacturer | Xigmatek |
Model Number | CAC-SYHH4-U01 |
Specification | |
Intel CPU Compatibility | Socket 2011 |
AMD CPU Compatibility | Socket FM1 |
Air Flow | 90.3 CFM (max) |
Noise | 18 dBA (max) |
Fan Connection | 4 Pin PWM |
Fan Speed | 800 to 1200 RPM |
Fan Dimensions | 140 x 140 x 25 mm |
Heat Pipes | 4 |
Materials | Copper |
Special Features | PWM Fan Control |
Package Contents | 1 x Xigmatek Prime Cooler |
He seems to do a good job. The only thing "strange" for me is that it is more efficient with a single fan. Why sell with two fans for worse results? ![]() |
^^^look at the ambiant temps---thats why it looks like its cooler(singlefan)^^^Quote
Look at ambient and delta temps,sure it does better with two fans ![]() |
