XIREX Stealth Waterblock
Testing Method
A Laing DDC Pro pump with OCLabs alternative top will be used to assist in making a comparison. I shall be looking specifically at pressure drop, flow resistance and cooling performance from within a CPU only water-cooling loop. I will be running the Laing DDC Pro pump at 9v,10v, 11v and 12v and the pressure drop and flow of the pump will be noted. All tests will be run 3 times to ensure the elimination of any oddities. I have included the setup details below:
Pressure Drop
For the pressure drop test I used a 25L portable water container filled with 20 litres of water, with a 1/2″ plastic threaded barb placed in the bottom to represent the reservoir. A stop tap was inserted immediately after the 1/2″ barb to allow for a faster water-block change. The True-Flow pressure meter was used to record the head pressure per 1 minute testing cycle. The pump was primed and let run for a short period to ensure that no air bubbles were left in the loop.
The first run made was with only the pump and pressure meter included in the loop and the water pressure noted. Then for second run the Xirex Stealth Waterblock was included into the loop and the drop in loop pressure recorded, and the same procedure was done for each of the water blocks.
* 1 x Laing DDC Pro pump with OCLabs alternative top @ 9/10/11/12v
* 1 x Xirex Stealth and XSPC X2O Delta Waterblock
* 1 x Powertech variable DC power supply (quoted accuracy /- 0.2V)
* 1 x Multi-meter
* 25L portable water container
* 1 x Glycerine filled True-Flow pressure meter. (kPa/PSI)
* 1/2″ ID XSPC tubing
* 1/2″ barbs
* 2 x stop-tap fittings
Flow
In a similar test to the pressure drop testing above, the flow test will highlight just how much the waterblocks restrict the natural flow of a water-cooling loop. Utilising a very simple setup consisting of a pump, I/2″ ID tubing, water blocks, bucket and a stopwatch we will see how far removed from the absolute flow of the pump, that the water blocks hinder flow. Incidentally, this is the same way that we test CPU blocks in past reviews…hence the included image below. Running the pump into the bucket for one minute and then measuring the amount of water pumped will be the ‘absolute flow’ of the pump. Once again the pump will be run at 9v,10v,11v and 12v.
To calculate the flow-loss or restriction of each waterblock, they will each be included into the loop (one at a time) and the same procedure followed. The flow rate will be recorded in Litres/ hour. All simulations will be run 3 times each to ensure uniformity of the results and an average then taken.
Loop Simulation and cooling performance
I have decided to impliment a control setup for the testing phase of this review. In doing so I have replicated a CPU only water-cooling loop similar to that in conventional water cooled setups, but also one that should return consistant and unbiased performance results. The Xirex Stealth and other waterblocks performance will be assessed at the Laing DDC Pro’s operating voltage of 12 volts. For each run, the pump was allowed to run for 20 mins to ensure the evacuation of all air from within the loop. The temperatures were taken at 30 minute intervals to allow them to ‘settle’. Two instances of ORTHOS will run simultaneously in order to simulate load.
Arctic Silver 5 was used as the TIM for testing all water blocks in this shootout I have recorded temperatures at idle, load and and an overclocked loaded state; all temperatures were taken using Core Temp 0.99 and water/ambient temperatures were taken using a common household mercury thermometer. The mercury thermometer was allowed 5 minutes to aclimatise to air and water and then the temperature recorded. The setup used has been included below:
* 1 x Laing DDC Pro pump with OCLabs alternative top @ 12v
* 1 x Multi-meter
* 1 x Toyota Camry heater core
* 1 x Scythe Ultra Kaze 2000RPM cooling fan
* 1/2″ barbs.
* 1 x Intel Q6600 SLACR G0 stepping quad-core processor
* 1 x ASUS P5B Deluxe wifi/App motherboard (bios version 1101)
* 1 Gigabyte 7600 graphics card
* Logitech generic mouse
* Logitech G15 keyboard
* 2GB OCZ PC2-6400 Titanium RAM
* Antec NEO EarthWatts 500W PSU
Please be mindful that all water block mountings were done so with a back plate.
Follow with me over the page to see the test results…
