Yate Loon D12SL-12 120mm Case Fan Review
Published: 7th February 2008 | Source: Aqua-PCs | Price: £3.99 |
I'd like to wager that there aren't many people who aren't familiar with the name Yate Loon. The Taiwanese based manufacturer of DC fans is very popular within the realms of the PC enthusiast, and more accurately, the water-cooling enthusiast.
Today I have been given the opportunity of reviewing some Yate Loon D12SL-12 120mm Fans. Will these fans deliver more air flow and an increase in static pressure which should make them the perfect candidates for heat sink and radiator cooling duties?
Let's move on and have a look at the Yate Loon D12SL-12's specifications....
Specifications
The Yate Loon D12SL-12 specifications were unashamedly taken from the products webpage.
Model: D12SL-12
Dimensions:120x120x25mm
Rated Voltage: 12 Volts
Operation Voltage: 6.5~13.8 Volts
Input current: 0.30 Amp Max
Operation temperature: -10 to +65 C
Storage temperature: -40 to +70 C
RPM: 1350 +/- 10%
CFM: 47
dB: 28
RPM: 1350 +/- 10%
CFM: 47
dB: 28
The specifications look par for the field for the Yate Loon D12SL-12, although I would have preferred to see a little more information on the fans like MTBF and bearing type.
They are brilliant fans indeed.Quote
Yate Loon FTMFW!Quote
Only fans i will use
Quote
would you recommend these over the noctuas?Quote
Yes as they are cheap about £5 each.Quote
