Yate Loon D12SL-12 120mm Case Fan Review
Packaging and A Closer Look
Published: 7th February 2008 | Source: Aqua-PCs | Price: £3.99 |
Packaging
The samples that I received from Aqua-Pcs were obviously OEM, and as such they forego any inclusion of advertising or adaptors that typically come with retail units. However, the packaging is sufficient enough to prevent any damage during transit.
A Closer Look
The Yate Loon D12SL-12 are a remarkably nice looking and well constructed fan. The fan itself comes with a standard 3-pin connector.
They are brilliant fans indeed.Quote
Yate Loon FTMFW!Quote
Only fans i will use
Quote
would you recommend these over the noctuas?Quote
Yes as they are cheap about £5 each.Quote
