Yate Loon D12SL-12 120mm Case Fan Review
Published: 7th February 2008 | Source: Aqua-PCs | Price: £3.99 |
So how well did the Yate Loon D12SL-12 120mm Fan perform in todays review?
The D12SL-12 whilst not being as quiet as the Noctua NF-P12 is certainly very quiet and would compliment any water-cooling setup. To be honest, I can see why the Yate Loon 120mm fan range has become so popular with the water-cooling enthusiasts. They are a great, no-frills fan which perform very well. But the absolute kicker here is the price! For a measly £3.99 (VAT Exclusive) you can own one of these, and you can own almost 4 for the price that you would pay for 1 Noctua NF-P12. These fans are an absolute steal.
The Good
• Excellent value
• Good performance
• Quiet
• Quality
The Mediocre
• Slightly noisier than the NF-P12 @12v
The Bad
• Nothing to report
A big thanks to Aqua-Pcs for supplying the review samples.
Discuss in our forum
They are brilliant fans indeed.Quote
Yate Loon FTMFW!Quote
Only fans i will use
Quote
would you recommend these over the noctuas?Quote
Yes as they are cheap about £5 each.Quote
