Zero-Infinity Free-Flow+ Review
Performance and testing
Performance and Testing
To provide continuity the test set up is as always
Gigabyte UD3R V2
Intel i7 950 @ 4GHz 1.25v & 1.35v
Mushkin Radioactive 2000MHz
HIS 6850
Cooler Master Storm Trooper
Corsair AX750w
For the first test we set our i7-950 overclocked to 200x20 @ 1.25v for a clock speed of 4.0GHz. We allow the system to idle for 30 minutes and then run Prime95 'maximum heat maximum stress' setting for a further 30 minutes.
After 30 minutes we note the temperatures of all cores and the ambient temperature of the room. An average of all cores is taken, then the ambient temperature is removed from this figure and this gives us the delta temperature. Delta is the temperature difference above ambient which is a truer reflection of the heat-sink performance rather than mere maximum figures. Testing in an Igloo or the Sahara would give vastly different maximum temperatures, yet the Delta could be the same.
The second test follows all steps from above but with a 200x21 @ 1.35v for 4.2GHz overclock, the extra voltage in this test allows us to see if the heat-sink can cope when extreme loads and overclocks are applied.
Things were looking fairly good, if not great, however I was quite surprised when the Free Flow+ failed the 4.4GHz test.  With it's sheer bulk I was expecting it to get a score, if not actually a good one.
«Prev 1 2 3 4 5 6 7 Next»
16-05-2012, 11:01:06
Jadarite
oh yes it's a Foxy Lady Quote
16-05-2012, 11:04:13
SieB
I'm liking the purple fans, shame about the performance and price though.Quote
16-05-2012, 11:05:48
Josh Weston
Good review, just a shame about the lacking performance at a ridiculous price.Quote
16-05-2012, 11:44:10
RzrTrek
Lovely review.. indeed, we would be better of getting ourselves an Noctua NH-D14! Quote
16-05-2012, 13:05:50
Lisa
Nice review, thanks. Purple is my fave colour and I wouldn't buy this. It looks garish and cheap. Aesthetics aside, you'd expect a twin-tower triple-fan to perform well or are they using the third fan just for marketing or to make up for some shortcomings? Either way, going by your results, they've failed.Quote
