Abit IP35 Pro Intel socket 775 Motherboard
Test Setup and Installation
Installation was possibly the easiest of any board I have reviewed so far on OC3D. The sheer amount of space created out of nowhere on the IP35 Pro is pretty nice and both my Scythe Infinity and my SwiftTech Apogee GT fitted no problems at all.
abit ip35 pro installed abit ip35 pro installed close
Now here's how I tested.
Test Setup
The following test setup was as following:
Intel Xeon 3070*
Abit IP35 Pro Motherboard
Sapphire X1600 Pro
1gb Mushkin HP2 6400 (4-4-4-10)
Hitachia Deskstar 7K160 SATA HDD
Sony DVD-Rom/CD-RW
Silverstone 560w ZEUS PSU
Silverstone TJ09 case
For comparison I used results from an earlier review by OC3D on the Abit AB9 Review, the AW9D max Review, the Asus P5B-E Plus Review, the abit IN9 32x Max Review and the XFX 650i Ultra Review
To test the motherboard I first ran it at stock using as stress test comprising of Orthos (dual Prime95), Folding @ Home running on both cores (set to idle priority) and RTHDRIBL running 1/2 screen. I let this run for 12hours to see how the board would fare.
The benches and tests used on the motherboard were:
Super PI 1m and 32m
SiSoft Sandra:
Processor Arithmatic
Procsssor Multemedia
Memory Bandwidth
Memory Latency
3DMark05 and 3DMark06 @ 1024 x 768 and 1280 x 1024
Counter Strike Source @ 1024 x 768 and 1280 x 1024
HD Tach
CPU Rendering
Note also that I lived with and used the board for a period of around 2 weeks to check out fully any issues that I found.
As usual there were no problems with installing Windows etc and this all worked out of the box, after simply changing the RAM timings to suit and memory voltage to 2.1v.
* Please note that there has been a change of CPU and although this is basically the same CPU, there may be differences in results.
«Prev 1 2 3 4 5 6 7 8 9 Next»
14-02-2007, 09:13:14
Great review Kemp, nice bunch of packaging akin to the rocketboy type of stuffz. I do wish the µguru thing was more of a 5.25 bay thingy tbh. Last time I checked, retailers were ramming these devices down peoples throats for like £11 or so - which amazes me why u never had one in the box ?!?
I would hope these good results will boost a tad more after some bios revisions, board to board I`d expect this one to be a bit better than shown - but meh..
Kewl, I recognize some of those photos too Quote
14-02-2007, 09:27:58
Excellent review as usual mate. The 680i's are toasty little sods for sure, and it's a pity that abit didn't even provide some form of active cooling to try and address the problem. Well done Quote
14-02-2007, 09:35:57
Their answer, and a few other manufs answer, seems to be to add this ugly looking heatpipe structure to stuff.
Heatpipes are great, but I don`t personally like the idea of 2 or 3 of the hs being connected together.Quote
14-02-2007, 09:38:11
2 or 3 connected together is fine, but that needs active cooling to work okQuote
14-02-2007, 10:51:54
Great review, Kemp, thanks for doing it as I was thinking of grabbing one. Now for my thoughts...
DAMN DAMN DAMN! I think the 680i chipset is good but not the king, would really like to see the 975X (or updated chipset) that can support nVidia's 8800 series gpu's in SLI... and done by ABIT. ABIT boards look great, and with the exception of the EZ PLUG for added graphics power, I like their layouts; not to mention my AW9D was rock-solid, even using an E6600 @ 3.7GHz... my 680i mobo can't touch it, only solid at 3.4GHz or lower.
Like the EZ CMOS as well, no more dip-switch installations! (newer mobos don't have problems like the old mobos after a bad OC, but it's the thought that counts!)
I personally don't see all the fuss over the passive cooling for the NB/SB. My case uses 4 120mm fans on the side of the case, so I get a lot of extra cooling... not to mention the little fan that came with my mobo for the NB, so I don't have a heating problem. I think it works fine, even without the little fan made for the NB; on the other hand, an enthusiast board should give the user the option to remove the passive to add active (fan) cooling solutions. The only thing I wonder about is the need for pipes from SB--NB--PWM... do the pipes really do anything for the cooling?
