AMD A8-3850 & Gigabyte A75M-UD2H Review
Testbed & AIDA64
Testbed
AMD A8-3850 Quad Core APU - 2.90GHz
Gigabyte A75M UD2H
4GB DDR3-1333 Memory
1TB Samsung F3 SATA II Drive
Windows 7 Home Premium
Overclocking
Be advised that overclocking can be rather hit and miss with these processors, depending on the motherboard that you purchase. At present AMD has not yet released a multiplier unlocked Black Edition processor for Socket FM1. As such, all overclocking endeavours are restricted to the HTT Base Clock only. In our case, no meaningful overclock was obtainable and so we will be proceeding with our testing process at reference clock speeds only.
CPU Performance
AIDA Extreme Edition
Returning to its roots by re-estabilishing the AIDA name, the latest iteration of the popular benchmark suite now includes optimisations over previous editions. With this in mind, remember not to compare these results against those conducted with older Everest software.
CPU Queen
CPU Queen is based on branch prediction and the misprediction penalties that are involved.
Right off the bat, we see a sizeable difference in performance between our quad core processors of similar core frequency. Clock for clock, it is apparent that the A8-3850 isn't much of an improvement over its older Athlon II X4 sibling.
CPU Photoworxx
PhotoWorxx as the name may suggest tests processors by means of invoking functions that are common to Photo Manipulation including Fill, Flip, Crop, Rotate, Difference and Colour to B&W conversion.
Here we can exhibit the operations that Sandy Bridge processors really seem to excel at, where our A8-3850 is left for dead.
CPU ZLib
This is an integer based benchmark that will test the CPU and Memory by means of the CPU ZLib compression library.
The gap narrows considerably in our data compression test. An additional cryptography benchmark based on the AES standard would have been included, but given that the AMD lacks the AES accelerating instruction set, the i5 2300 beats it by hilarious margins; it simply wasn't worth including.
«Prev 1 2 3 4 5 6 7 8 Next»
01-08-2011, 09:53:33
SieB
Good review Mul Quote
01-08-2011, 10:43:51
alienware
This is going to be a very hard product to review.
Mostly because there is nothing else like it on the market.
I'm a little confused as to why this was pitted against an I5 when the I5 is clearly far more expensive.
£103.99 inc for the Llano from Ebuyer, £137 inc for the I5.
The comparissons should be against the I3. Now sure, as a CPU the I3 is faster. However, the GPU aboard the 3850 poos on the I3 and is actually playable at sensible resolutions. Every other review I have read have pitted it like for like, so I can't understand why this has been benched against a CPU that puts another 35% on top of what the 3850 costs.
I can only summise it was because OC3D maybe didn't have an I3 to put it against?Quote
01-08-2011, 12:07:10
AxJaWz
I agree but nice review!Quote
01-08-2011, 13:45:52
jonowee
Oh FFS Gigabyte, I want vomit when I see SATA ports stick straight out of motherboard. Yeah this motherboard has some odd mix of price, IGP, and Crossfire capability.Quote
01-08-2011, 14:03:17
Mul.
Originally Posted by SieB View Post
Good review Mul
Thank you. I haven't published anything since February - glad to have been able to help out a little
Bingo.
Indeed an i3 wasn't available to compare it with, however I had left hints along the way that the price of the A8-3850 accounts for its inferior core for core and clock for clock (gag) performance. However, I feel that the article was able to highlight what was most important. Entry level multimedia users don't need outright core processor performance - combine an average CPU with a good enough GPU and their most complex needs are satisfied. Intel's Atom + nVidia ION as well as AMD's own FUZION E350 is a testament to this.
I maintain that so long as you build a FM1 system in a cut price fashion, it represents very good value for money. However as I've said in the review, you've got to be bonkers to spend big £££ on a A75 FM1 board.Quote
