AMD A8-3850 & Gigabyte A75M-UD2H Review
Multimedia Benchmarks & Gaming
Multimedia & Gaming Benchmarks
Futuremark PCMark7
PCMark7 is a very recent multimedia benchmark from Futuremark. Designed for Windows 7, it is ideal for the purposes of our testing. Like its predecessors, it tasks all core components of the computer. The Processor, GPU, RAM and HDD/SSD appear to have a significant bearing on the scores that follow.
By all means, these are very respectable scores. While our Core i5 2300 was not in hand for this test, it is known that the obtained score is roughly around the same ballpark, if a little lower than a comparable i5 configuration. PCMark 7 does appear to benefit from having more CPU grunt on tap and this is where a Core i5 setup would cover the gains that the AMD A8-3850 would otherwise gain from the Video/Gaming related benchmarks.
Futuremark 3DMark Vantage
We all know 3DMark Vantage for the reliable benchmark measure that it tends to be. It is hoped that this application will fully leverage the A8-3850 for what its worth.
It certainly did. While it identifies the AMD's core processing limitations, it also backs up claims that the A8-3850's 400 stream GPU will allow it to perform considerably better overall.
Far Cry 2
But how exactly does this AMD APU fair in real life gaming? Far Cry 2 is certainly not the latest gaming sensation however it remains to be a reliable measure for GPU performance.
The results are not bad at all. With image settings cranked up and copious amounts of Anti Aliasing, the game was surprisingly playable. Aside some stuttering when the whole gaming environment is engulfed with explosions, the fluidity was generally quite playable overall.
Unfortunately the same can't be said at 1080p resolutions. It is clear that some more GPU grunt and some dedicated graphics memory is required to really deal with 1920x1080 and above.
«Prev 1 2 3 4 5 6 7 8 Next»
01-08-2011, 09:53:33
SieB
Good review Mul Quote
01-08-2011, 10:43:51
alienware
This is going to be a very hard product to review.
Mostly because there is nothing else like it on the market.
I'm a little confused as to why this was pitted against an I5 when the I5 is clearly far more expensive.
£103.99 inc for the Llano from Ebuyer, £137 inc for the I5.
The comparissons should be against the I3. Now sure, as a CPU the I3 is faster. However, the GPU aboard the 3850 poos on the I3 and is actually playable at sensible resolutions. Every other review I have read have pitted it like for like, so I can't understand why this has been benched against a CPU that puts another 35% on top of what the 3850 costs.
I can only summise it was because OC3D maybe didn't have an I3 to put it against?Quote
01-08-2011, 12:07:10
AxJaWz
I agree but nice review!Quote
01-08-2011, 13:45:52
jonowee
Oh FFS Gigabyte, I want vomit when I see SATA ports stick straight out of motherboard. Yeah this motherboard has some odd mix of price, IGP, and Crossfire capability.Quote
01-08-2011, 14:03:17
Mul.
Originally Posted by SieB View Post
Good review Mul
Thank you. I haven't published anything since February - glad to have been able to help out a little
Bingo.
Indeed an i3 wasn't available to compare it with, however I had left hints along the way that the price of the A8-3850 accounts for its inferior core for core and clock for clock (gag) performance. However, I feel that the article was able to highlight what was most important. Entry level multimedia users don't need outright core processor performance - combine an average CPU with a good enough GPU and their most complex needs are satisfied. Intel's Atom + nVidia ION as well as AMD's own FUZION E350 is a testament to this.
I maintain that so long as you build a FM1 system in a cut price fashion, it represents very good value for money. However as I've said in the review, you've got to be bonkers to spend big £££ on a A75 FM1 board.Quote
