AMD Phenom II X4 965 BE
Synthetic CPU Results
SiSoftware
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
SuperPI
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching. It should be noted that while the application is fantastic as a measure of a processor's performance compared to another processor of the same product family, it is known to be a mediocre choice of application to compare processors between different product families and brands. Also note that SuperPi is a single threaded application.
Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
PassMark Software
PassMark is a popular benchmarking suite which test all aspect of PC hardware.The CPU test examines Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more. Each CPU test was performed a total of 5 times, with an average being calculated from the middle three results.
Result Analysis
As we can see, the higher default clock speed of the 965 gives it an advantage in the CPU benchmarks. The i7 920 is still faster in all of these benchmarks, despite it's slower clock. The hyperthreading technology obviously does it's job here.
«Prev 1 2 3 4 5 6 7 Next»
17-08-2009, 11:07:54
FarFarAway
A predictable outcome, but a step in the right direction none-the-less. I keep getting tempted to pick up an AMD CPU just for the sheer hell of it, but other stuff tends to get priorities
Good review Quote
17-08-2009, 11:09:58
mayhem
Well thought out set of phrases.
Nice review all though the cpu is not just yet my cup of tee, how ever i will sing a song of Boom Boom Boom Let me way Eh Oh !!!!!! Or was it just a fizz and pop when it blew
nice to see you pushing it to its own demise .. are you going to get a new sample to play with.Quote
17-08-2009, 12:00:30
JN
Really hoping so as 4.1GHz felt achievable even on the basic Gigabyte board that was used. Even more interesting than the max oc will be what results it gets at 4-4.1ghzQuote
17-08-2009, 12:04:21
Mul.
It was very unfortunate that it bit the dust so prematurely. I was surprised because I and many others have pushed AMD Phenom II CPU's past 1.50V on air without any sign of it causing any damage. Overclocked performance would have been something particularly interesting to see as I've found that these processors scale rather well with clock speed increases especially with ramped up northbridge frequencies and DDR3. As I mentioned before, it's also quite well known for the Phenom II to overclock as much as 200MHz less on a 64bit operating system than on a 32bit OS.Quote
17-08-2009, 14:45:50
Rastalovich
It's a little more unfortunate that the E8400/ROG-P45/DDR2 was used as the C2D comparison.
Not that it'd obviously stake any claims to outperform anything, but mentioning a Q9550 - that would have been nice. And a X48 DDR3 sporting mobo too, atleast a P45 DDR3 - particularly when emphasis is made on artificial benchmarks.
I personally see 775 as still a viable option.Quote
