AMD Phenom II X4 965 BE
PCMark Vantage Results
PCMark Vantage
PCMark Vantage is the latest benchmarking suite from Futuremark. Differing significantly from their 3DMark suites, PCMark performs a series of benchmarks designed to recreate and benchmark scenarios of a PC being used for everyday tasks. Vantage has a Vista only requirement as it actually relies on several different components from the OS in order to run correctly.
Results Analysis
As usual, the 920 beats the 965, and the 965 beats the 955. Apart from in the memory benchmarks, where the 965 shines due to the mature intergrated memory controller rather than Intel's new solution. The 920 delivers the higher scores due to the hyperthreading support but the 965 does give a nice boost over the 955 due to the higher clock of 3.2GHz
«Prev 1 2 3 4 5 6 7 Next»
17-08-2009, 11:07:54
FarFarAway
A predictable outcome, but a step in the right direction none-the-less. I keep getting tempted to pick up an AMD CPU just for the sheer hell of it, but other stuff tends to get priorities
Good review Quote
17-08-2009, 11:09:58
mayhem
Well thought out set of phrases.
Nice review all though the cpu is not just yet my cup of tee, how ever i will sing a song of Boom Boom Boom Let me way Eh Oh !!!!!! Or was it just a fizz and pop when it blew
nice to see you pushing it to its own demise .. are you going to get a new sample to play with.Quote
17-08-2009, 12:00:30
JN
Really hoping so as 4.1GHz felt achievable even on the basic Gigabyte board that was used. Even more interesting than the max oc will be what results it gets at 4-4.1ghzQuote
17-08-2009, 12:04:21
Mul.
It was very unfortunate that it bit the dust so prematurely. I was surprised because I and many others have pushed AMD Phenom II CPU's past 1.50V on air without any sign of it causing any damage. Overclocked performance would have been something particularly interesting to see as I've found that these processors scale rather well with clock speed increases especially with ramped up northbridge frequencies and DDR3. As I mentioned before, it's also quite well known for the Phenom II to overclock as much as 200MHz less on a 64bit operating system than on a 32bit OS.Quote
17-08-2009, 14:45:50
Rastalovich
It's a little more unfortunate that the E8400/ROG-P45/DDR2 was used as the C2D comparison.
Not that it'd obviously stake any claims to outperform anything, but mentioning a Q9550 - that would have been nice. And a X48 DDR3 sporting mobo too, atleast a P45 DDR3 - particularly when emphasis is made on artificial benchmarks.
I personally see 775 as still a viable option.Quote
