AMD Raven Ridge Ryzen 3 2200G and Ryzen 5 2400G Review
x265
Published: 16th February 2018 | Source: AMD | Price: |
x265
As replacements for the Ryzen 3 1200 and Ryzen 5 1400, it is hard to argue with the performance offered by the 2200G and 2400G, delivering performance that not only surpass their previous generation counterparts but even the models above them.
In our x265 benchmarks, we can see the 2200G surpass the Ryzen 3 1300X and get within striking distance of our 4GHz 1200 and 1300X overclocked results, which is a remarkable improvement given this products pricing an inclusion of integrated graphics. The Ryzen 5 2400G achieves a similar feat, surpassing the 1500X to offer an experience that is similar to the Intel i5 7600K.
When compared to its last generation counterparts the Raven Ridge 2000G series of processors offer a notable performance increase as well as (effectively free) integrated graphics hardware, delivering a huge boost in value for money for low-end AMD users.
HDMI 2.0? I got a HDMI only 4K TV. The 2200G will be the cheapest solution by far, that supports hdmi 2.0. The only native alternative is 1030/rx550, which is almost alone the cost of the 2200G.Quote
What is the test bench setup?
HDMI 2.0? I got a HDMI only 4K TV. The 2200G will be the cheapest solution by far, that supports hdmi 2.0. The only native alternative is 1030/rx550, which is almost alone the cost of the 2200G. |
HDMI 2.0 will be down to what your motherboard supports, as some AM4 motherboards only have HDMI 1.4 as far as I am aware.Quote
The Video is now in the review.
Test bench setup is on page 2 at the bottom. HDMI 2.0 will be down to what your motherboard supports, as some AM4 motherboards only have HDMI 1.4 as far as I am aware. |
"AMD Ryzen 3 2200G & Ryzen 5 2400G
ASUS Prime Z370-PLUS
G.Skill Flare X 3200MHz memory
Corsair RM1000i
Corsair MP500 512GB
Corsair H110i GT
Windows 10"
That probably should be x370-PLUS, Z370-PLUS? Anyway, i missed it down there, so thanks for answering.
As for what motherboards supports, the specs are a mess:
X370 XPOWER GAMING TITANIUM
"-1 x HDMI 2.0 port, supports a maximum resolution of [email protected] (1)
-1 x DisplayPort, supports a maximum resolution of [email protected] (2)
(1) Only support when using a 7th Gen A-series/ Athlon processors
(2) Maximum shared memory of 2048 MB"
What does that mean?
GA-AX370-Gaming K7
" Integrated Graphics Processor:
1. 1 x HDMI port, supporting a maximum resolution of [email protected] Hz
* Support for HDMI 1.4 version.
2. Maximum shared memory of 2 GB
* Actual support may vary by CPU."
These specs can actually mean a lot of different things. Like being written for the Athlon CPUs available at MB launch or like for the K7, that they maybe but not clearly only support HDMI 1.4. It is clearly CPU dependent, and Athlons only support HDMI 1.4, so what is the story with the MSI board? The HDMI on the MSI is after all only available using an last gen Athlon?
No body seems to know, but a lot of people are opinionated. I would really appreciate it, if you could try it out.
As for HDMI 1.4, max refresh rate for 2D is 24Hz.Quote
