AMD Raven Ridge Ryzen 3 2200G and Ryzen 5 2400G Review
SiSoft Sandra - Cryptography and Financial/Scientific Analysis
In our Sisoft Sandra benchmarks, AMD's Raven Ridge 2200G and 2400G are capable of surpassing both their previous generation counterparts with ease, even while those models are overclocked.
It is likely that these changes in performance are due to Raven Ridge's lover cache latencies, allowing these new CPU models to access data faster, delivering a performance uplift.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 Next»
12-02-2018, 15:00:18
RobM
no video Tom?Quote
12-02-2018, 15:54:09
Frode B Nilsen
What is the test bench setup?
HDMI 2.0? I got a HDMI only 4K TV. The 2200G will be the cheapest solution by far, that supports hdmi 2.0. The only native alternative is 1030/rx550, which is almost alone the cost of the 2200G.Quote
12-02-2018, 16:45:49
tinytomlogan
Video now in the reviewQuote
12-02-2018, 17:01:14
WYP
Originally Posted by RobM View Post
no video Tom?
The Video is now in the review.
Test bench setup is on page 2 at the bottom.
HDMI 2.0 will be down to what your motherboard supports, as some AM4 motherboards only have HDMI 1.4 as far as I am aware.Quote
12-02-2018, 17:49:51
Frode B Nilsen
Thanks. The test bench probably has a typo, that confused me on the MB:
"AMD Ryzen 3 2200G & Ryzen 5 2400G
ASUS Prime Z370-PLUS
G.Skill Flare X 3200MHz memory
Corsair RM1000i
Corsair MP500 512GB
Corsair H110i GT
Windows 10"
That probably should be x370-PLUS, Z370-PLUS? Anyway, i missed it down there, so thanks for answering.
As for what motherboards supports, the specs are a mess:
X370 XPOWER GAMING TITANIUM
"-1 x HDMI™ 2.0 port, supports a maximum resolution of [email protected] (1)
-1 x DisplayPort, supports a maximum resolution of [email protected] (2)
(1) Only support when using a 7th Gen A-series/ Athlon™ processors
(2) Maximum shared memory of 2048 MB"
What does that mean?
GA-AX370-Gaming K7
" Integrated Graphics Processor:
1. 1 x HDMI port, supporting a maximum resolution of [email protected] Hz
* Support for HDMI 1.4 version.
2. Maximum shared memory of 2 GB
* Actual support may vary by CPU."
These specs can actually mean a lot of different things. Like being written for the Athlon CPUs available at MB launch or like for the K7, that they maybe but not clearly only support HDMI 1.4. It is clearly CPU dependent, and Athlons only support HDMI 1.4, so what is the story with the MSI board? The HDMI on the MSI is after all only available using an last gen Athlon?
No body seems to know, but a lot of people are opinionated. I would really appreciate it, if you could try it out.
As for HDMI 1.4, max refresh rate for 2D is 24Hz.Quote
