AMD Raven Ridge Ryzen 3 2200G and Ryzen 5 2400G Review
Cinebench R15
Cinebench R15
In Cinebench we can see that AMD's new Raven Ridge CPU can pack a punch when compared to their last-generation counterparts.
Both the Ryzen 3 2200G and the Ryzen 5 2400G surpassing their Ryzen 3 1300X and Ryzen 5 1500X at stock, CPUs that are higher up the AMD CPU lineup than the Ryzen 3 1200 and the Ryzen 5 1400 CPUs that these models are set to replace. Both models sit closer to overclocked versions of their previous generation counterparts than their stock performance.
This boost is an impressive showing from AMD, especially when considering that this is a mid-generation CPU refresh, not a next-generation architecture or "tock" advancement to a new manufacturing process.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 Next»
12-02-2018, 15:00:18
RobM
no video Tom?Quote
12-02-2018, 15:54:09
Frode B Nilsen
What is the test bench setup?
HDMI 2.0? I got a HDMI only 4K TV. The 2200G will be the cheapest solution by far, that supports hdmi 2.0. The only native alternative is 1030/rx550, which is almost alone the cost of the 2200G.Quote
12-02-2018, 16:45:49
tinytomlogan
Video now in the reviewQuote
12-02-2018, 17:01:14
WYP
Originally Posted by RobM View Post
no video Tom?
The Video is now in the review.
Test bench setup is on page 2 at the bottom.
HDMI 2.0 will be down to what your motherboard supports, as some AM4 motherboards only have HDMI 1.4 as far as I am aware.Quote
12-02-2018, 17:49:51
Frode B Nilsen
Thanks. The test bench probably has a typo, that confused me on the MB:
"AMD Ryzen 3 2200G & Ryzen 5 2400G
ASUS Prime Z370-PLUS
G.Skill Flare X 3200MHz memory
Corsair RM1000i
Corsair MP500 512GB
Corsair H110i GT
Windows 10"
That probably should be x370-PLUS, Z370-PLUS? Anyway, i missed it down there, so thanks for answering.
As for what motherboards supports, the specs are a mess:
X370 XPOWER GAMING TITANIUM
"-1 x HDMI™ 2.0 port, supports a maximum resolution of [email protected] (1)
-1 x DisplayPort, supports a maximum resolution of [email protected] (2)
(1) Only support when using a 7th Gen A-series/ Athlon™ processors
(2) Maximum shared memory of 2048 MB"
What does that mean?
GA-AX370-Gaming K7
" Integrated Graphics Processor:
1. 1 x HDMI port, supporting a maximum resolution of [email protected] Hz
* Support for HDMI 1.4 version.
2. Maximum shared memory of 2 GB
* Actual support may vary by CPU."
These specs can actually mean a lot of different things. Like being written for the Athlon CPUs available at MB launch or like for the K7, that they maybe but not clearly only support HDMI 1.4. It is clearly CPU dependent, and Athlons only support HDMI 1.4, so what is the story with the MSI board? The HDMI on the MSI is after all only available using an last gen Athlon?
No body seems to know, but a lot of people are opinionated. I would really appreciate it, if you could try it out.
As for HDMI 1.4, max refresh rate for 2D is 24Hz.Quote
