AMD Ryzen 5 1400, 1500X and 1600X CPU Review
Geekbench, Realbench, Userbench
Published: 11th April 2017 | Source: AMD | Price: |
Moving into our benchmarks that test the whole system, the results go pretty much as you'd expect. The Ryzen 5 1600X makes great use of its hexcore architecture, whilst the 1500X outperforms the 1400 in both stock and overclocked setups.
I am building new system for a friend, and i am undecided between Intel, or AMD which is the good thing. Last year it was go with intel... No brainer.
1500X could be the next AMD best seller.Quote
Thanks for the review/s. Only site I've found so far with all of the 5 range.
Awesome
Thanks for the review Tom you gave all the info needed and I had a big enough coffee cup to watch it all in 1 sitting. They just need some better looking B350 motherboardsQuote
I feel sorry for tom even though in the video he says if you play games that need frequency then go Intel otherwise the 1500x is great for gaming he is still a biased AMD fanboy going by FB comments because Intel was better by 5 fps in other games.
Thanks for the review Tom you gave all the info needed and I had a big enough coffee cup to watch it all in 1 sitting. They just need some better looking B350 motherboards |
TBH if you only do gaming on a PC and nothing else then I guess it's worth buying Intel. Anything else? AMD have it covered
