AMD Ryzen 5 5600X Review
PCMARK 10
PCMARK 10
The umpteen versions of PCMARK used a selection of applications to test your systems utility as an overall setup for work. Each version came with its own foibles wherein it has overly weighted certain aspects of the tests when calculating the final score, but it was still useful when comparing like for like. The latest PCMARK 10 is perfectly suited to take advantage of all the latest optimisations and is much cleaner in its score calculations.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Next»
07-11-2020, 18:50:09
grec
Great write up, looks like a strong little gaming chip, has anyone tried per core overclocking on this?Quote
07-11-2020, 20:09:01
AngryGoldfish
4.7Ghz at only 1.2v is very nice. But that PBO overclock is also very tasty.
Has anyone seen how these new Ryzen CPUs perform in music production workloads? That was another weak point for past iterations of Zen.Quote
07-11-2020, 20:26:44
Greenback
Seems AMD have all needs for pc covered with this round of cpu releases, really no reason to look at intels offerings.
P.s I always watch until the end of the video'sQuote
07-11-2020, 21:25:02
Dawelio
From all the reviews I've seen over the past days, this particular CPU seems to be one hell of a CPU. First time I've actually ordered it straight away.
With this though and this might be a bit off topic, but I had one or two thoughts of Aliens logics behind this decision this time around, so thank you for your past inputs Alien!Quote
08-11-2020, 07:24:19
ET3D
The DaVinci Resolve benchmarks looks really weird. The 5900X performs the same as the 3600XT at stock, but higher than the 3950X with PBO? The 10900K performs worse than everything but the 3400G? Makes no sense.Quote
