AMD Ryzen memory optimisation - The effect of tRC timings
VRMARK
AMD Ryzen memory optimisation trick
VRMARK
In VRMARK our system is GPU bound, with our changes in memory timings making minimal differences of less than 100 points, which is certainly not enough to worry about.
This change in memory timings will not have an impact in all application, only affecting situations where programs are either memory or CPU constrained.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Next»
18-07-2017, 13:59:45
Dawelio
I like it how the test rig specs in the box say "1080 Founders Edition", although the picture of the PC under it shows and ASUS Strix card Quote
18-07-2017, 14:02:05
WYP
That is the thing with test beds, hardware changes all the time. I can't take pics with every hardware configuration.Quote
18-07-2017, 14:08:58
Dawelio
No no, I understand dude. I was just pointing it out, not to put it in your face or anything though.Quote
18-07-2017, 16:49:54
harrison
For whatever it's worth, my memory/motherboard does not seem to exhibit this issue. My XMP 2.0 values populated and booted without any fussing, and the tCR value is accurate.
MB: ASRock AB350M Pro4, BIOS v2.5 (AGESA 1.0.0.6)
Ram: Corsair LPX 2x8GB 3200MHz C16 (CMK16GX4M2C3200C16S)
Timings: 16-18-18-36-54-1 (tCAS-tRC-tRP-tRAS-tCS-tCR)
https://valid.x86.fr/te3x7z
A new update was just released today for AGESA 1.0.0.6a, so I'll need to see how that impacts things, but in this one case at least, things appear to not wonky.Quote
18-07-2017, 17:12:14
WYP
Well that is certainly a positive thing to hear, one of the main points for this is to raise awareness and get a potential fix in future BIOS' if possible. I do remember the Taichi having the issue at launch, so this is likely a recent development.
Hopefully other manufacturers will soon follow suit. It is memory performance that is simply sitting on the table.Quote
