AMD Ryzen memory optimisation - The effect of tRC timings
Gears of War 4
AMD Ryzen memory optimisation trick
Gears of War 4 - 1080p Ultra Settings
In Gears of War 4, we have found that our changes to memory timings do have an impact on performance, with a notable increase in minimum framerate when using 2666MHz memory and a smaller boost when running the game with 3200MHz memory.
Any increase in minimum FPS is always a good thing to have, as it will make the game feel smoother and more consistent. Nobody wants to see large framerate dips while gaming, so anything that can deliver boost performance in this regard is a good thing.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Next»
18-07-2017, 17:59:45
Dawelio
I like it how the test rig specs in the box say "1080 Founders Edition", although the picture of the PC under it shows and ASUS Strix card Quote
18-07-2017, 18:02:05
WYP
That is the thing with test beds, hardware changes all the time. I can't take pics with every hardware configuration.Quote
18-07-2017, 18:08:58
Dawelio
No no, I understand dude. I was just pointing it out, not to put it in your face or anything though.Quote
18-07-2017, 20:49:54
harrison
For whatever it's worth, my memory/motherboard does not seem to exhibit this issue. My XMP 2.0 values populated and booted without any fussing, and the tCR value is accurate.
MB: ASRock AB350M Pro4, BIOS v2.5 (AGESA 1.0.0.6)
Ram: Corsair LPX 2x8GB 3200MHz C16 (CMK16GX4M2C3200C16S)
Timings: 16-18-18-36-54-1 (tCAS-tRC-tRP-tRAS-tCS-tCR)
https://valid.x86.fr/te3x7z
A new update was just released today for AGESA 1.0.0.6a, so I'll need to see how that impacts things, but in this one case at least, things appear to not wonky.Quote
18-07-2017, 21:12:14
WYP
Well that is certainly a positive thing to hear, one of the main points for this is to raise awareness and get a potential fix in future BIOS' if possible. I do remember the Taichi having the issue at launch, so this is likely a recent development.
Hopefully other manufacturers will soon follow suit. It is memory performance that is simply sitting on the table.Quote
