AMD Ryzen memory optimisation - The effect of tRC timings
Changing tRC timings and stability testing
Published: 14th July 2017 | Source: OC3D Internal testing | Price: |
To start off, anyone who wishes to use this memory tweak will need to first have a system with stable memory, so please make sure that your chosen memory already runs at its native speeds and is 100% stable before starting.
Secondly, it must be remembered that this can be classified as memory overclocking and as such should be done carefully and in the knowledge that overclocking using the wrong methods can result in an unstable or at worst a damaged system.
These settings vary from AMD's stock values and as such are not guaranteed to work, so we recommend that those who wish to tweak their memory know how to clear the CMOS of their motherboard and has several memory heavy programs and benchmarking utilities to test stability.
Starting off
First users should find out what their memory tRC timings should be, which can be commonly found using CPU-Z. tRC is typically the values of tRP (RAS# Precharge) and tRAS added together, which is this case is 48 (14+34). This is found for this memory on the XMP-3200 section of the memory's timings table.
Your tRC value should not go lower that tRP+tRAS, as this will cause system instability. tRC can be higher than this value, but going lower will cause unnecessary problems.
This means that we are planning to reduce the tRC time from 75 to 48 in the BIOS, which is a 36% reduction, which should increase your system memory performance in certain scenarios.
It is important to note that tRC should not be lower than tRP + tRAS for stability reasons, though you can use speeds that are higher than this if required. Setting your tRC timings to low can prevent your system to fail to boot, requiring a CMOS reset.
Changing your memory tRC timings
To change your tRC timings you will need a motherboard that uses AMD's latest AGESA 1.0.0.6 update, which for the purposes of this guide will be ASUS' Crosshair VI Hero. This setting will be found in DRAM Timing Controls and is commonly directly under your tRAS timing.
Before you change this setting make sure your memory is already running at its correct timings and voltages, which should set up correctly if you are using your motherboard's DCOP or A-XMP memory profiles.
From here users will be able to input their own tRC value, which you have already recorded from your stock memory profiles. From here save your BIOS setting changes and reboot your system.
(memory timings before changes)
Stability Testing and Validation
To confirm stability we advise users to first re-enter the BIOS to confirm that their settings have saved correctly and then enter Windows.
If Windows does not boot correctly users should attempt to re-enter the BIOS and then change their tRC setting to a higher value. We have tested multiple memory kits with this method and the previously stable memory that we have tested has worked with modified/optimised tRC values.
(BIOS with improved tRC timings)
When booted into Windows users should check that their memory is running at their selected memory timings using CPU-Z.
Stability Testing
For stability testing, we recommend that a variety of benchmarks are used, as no single tool is a surefire way to check for memory instability. OCCT with heavy workloads setting is a good start alongside AIDA 64's memory test suite, though we would recommend adding other tools like Geekbench into the mix for good measure.
Treat this like any other form of overclocking, be careful with any BIOS changes and make sure you conduct sufficient stress testing before putting you your system back to work.
I like it how the test rig specs in the box say "1080 Founders Edition", although the picture of the PC under it shows and ASUS Strix card
That is the thing with test beds, hardware changes all the time. I can't take pics with every hardware configuration.
MB: ASRock AB350M Pro4, BIOS v2.5 (AGESA 1.0.0.6)
Ram: Corsair LPX 2x8GB 3200MHz C16 (CMK16GX4M2C3200C16S)
Timings: 16-18-18-36-54-1 (tCAS-tRC-tRP-tRAS-tCS-tCR)
https://valid.x86.fr/te3x7z
A new update was just released today for AGESA 1.0.0.6a, so I'll need to see how that impacts things, but in this one case at least, things appear to not wonky.Quote
For whatever it's worth, my memory/motherboard does not seem to exhibit this issue. My XMP 2.0 values populated and booted without any fussing, and the tCR value is accurate.
MB: ASRock AB350M Pro4, BIOS v2.5 (AGESA 1.0.0.6) Ram: Corsair LPX 2x8GB 3200MHz C16 (CMK16GX4M2C3200C16S) Timings: 16-18-18-36-54-1 (tCAS-tRC-tRP-tRAS-tCS-tCR) https://valid.x86.fr/te3x7z A new update was just released today for AGESA 1.0.0.6a, so I'll need to see how that impacts things, but in this one case at least, things appear to not wonky. |
Hopefully other manufacturers will soon follow suit. It is memory performance that is simply sitting on the table.Quote
