Published: June 15, 2008 |
Source:
ASUS |
Author:
Rich Weatherstone
Asus Crosshair II AM2+ Motherboard
Â
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.Â
Â
Â
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on Software and Hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining 3.
Â
7-Zip is an open source winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
Â
Â
Â
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The “Long bench” was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
Â
Â
Â
Cinebench 10 is a benchmarking tool based on the powerful 3D software Cinema 4D. The suite uses complex renders to gauge the performance of the entire PC system in both single-core and multi-core modes. Testing was performed a total of 5 times with the highest and lowest results being omitted and an average created from the remaining 3 results.
Â
Results and Observations
The small overclock has resulted in an all round average increase in performance which is not surprising. Nonetheless it’s always good to see the fruits of your labour and confirming that your system is running faster than previously. Let’s see if how the 3D applications fair.
