Asus Crosshair III Formula vs DFI DK 790FXB M3H5 Face-Off
PCMark Vantage
Published: 26th July 2009 | Source: AMD | Price: £140 |
PCMark Vantage is the latest benchmarking suite from Futuremark. Differing significantly from their 3DMark suites, PCMark performs a series of benchmarks designed to recreate and benchmark scenarios of a PC being used for everyday tasks. Vantage has a Vista only requirement as it actually relies on several different components from the OS in order to run correctly.
Results Analysis
Overall, the DFI DK 790FXB M3H5 appears to be favoured with the Asus board not too far behind. This is perhaps in contrast to our own run of benchmarks. Surprisingly, the Intel setup was left lagging behind in the majority of test run today. Once has to consider however that the Intel CPU is the entry level one and the AMD the range topping version. Price comparison though turns the tables upside down as the range topping AMD CPU is actually much cheaper than the i7 920.
Let's head over to the conclusion where I try to put my thoughts into some sort of order...
Asus calling that a top of the range bord ...
If i was paying that much id expect 6 sata and water cooling blocks for the chip set and so much more ...
Is it relay worth that much ...
Excellent review.Quote
Compared to the cost of i7 motherboards its a freakin bargain!Quote
yeh i7 is just extortion ...
What happened to our lovely sub £100 boards that used to perform like "some thing off a stick" ..
Now there filled with useless rubbish and fancy packaging that costs more than half the bit's inside the box.
I would like my £100 Sub boards that performed back .... This is a recession were in ...
God if i was a reviewer id be the most hated reviewer out there because im so critical or half the gear they stuff inside these things.
Reviews all say yeah you get 6 sata leads and a LCD and loads of fancy this and that. Me i say remove that and drop the price by £50 / £60 quid and ill be happy.
Half the Gimmicks are just that "Pure Gimmicks" nothing more.
Im trying to avoid this coming out as a rant more trying to point out facts.
Bling is just chav.....
Don't forget im a little old fashioned as well.Quote
I totally agree. However I do like a well rounded product. Packaging is a major plus point with me and they score highly if its done right.
Prices have rocketted though I do agree and yeah they could cut out half the crap but when you compare the Asus vs the DFI here, both costing more or less the same the Asus wins hands down for the bling and accessories alone, let alone performance.Quote
Excellent review.
Shame on DFI with some of their onboard choices ALC885 and Marvell ? c'mon - throw in the jumper and I'd expect the mobo to be cheaper.
The ASUS tho, even as the DFI kept up with it (and it can be assumed better with the model up), very very nice figures for the gamer.
Things are looking green whilst blue seems to want to confuse. Weird that cos in other respects AMD would be ... red
