Asus mATX ROG Rampage II Gene X58 Motherboard
Â
HDTach is a free hard disk benchmarking program from SimpliSoftware. This benchmark is not only capable of producing results on hard disk access times but also CPU usage required during disk access. The “Long bench” was run a total of 5 times with the highest and lowest results being omitted and an average calculated from the remaining 3 results.
Â
Â
Â
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Â
Â
Results Analysis
The Rampage IIÂ Gene could not repeat it’s astonishing performance in the memory benchmarks here falling back again to the middle of the pack and scoring equally with the remaining motherboards on test. This is not surprising considering all the boards on test use the same ICH10R SATA controller.
Let’s see how the perform with our multimedia benchmark suite…
