Asus P5K P35 Socket 775 Motherboard
BIOS & Overclocking
Published: 4th June 2007 | Source: Asus | Price: |
As with all of Asus' most recent motherboards, the P5K is based around a BIOS from Phoenix Technologies. Some enthusiasts tend to favor the Award BIOS layout over Phoenix, but it's extremely hard to find fault with the overall layout and wealth of features available on the P5K.
Front-Side Bus speeds are adjustable in 1mhz increments all the way from 200mhz up to a rather insane 800mhz. Of course, the board isn't actually capable of hitting such a high FSB speed, but I can only think that such a wide FSB range was placed in the BIOS to remove any possibility of a "locked down" setting from hindering some insane liquid nitrogen overclocking fun!
Voltage options are equally as flexible, with vcore available in 0.0125v increments from 1.000v all the way up to 1.700v and vdimm ranging from 1.80v to 2.55v in 0.05v steps. More information on the voltage and overclocking options can be seen in the table below:
Option | Available Range |
FSB | 200-800mhz |
PCI-E Clock | 100-150mhz |
VCore Voltage | 1.000-1.700v |
CPU PLL Voltage | 1.50-1.80v |
Northbridge Voltage | 1.25-1.70v |
Southbridge Voltage | 1.05-1.20v |
Memory Voltage | 1.80-2.55v |
Another feature brought over from the P5B series is the "O.C Profile" utility. This essentially allows you to save your current BIOS settings to a restorable profile, and can be very handy if you've spent a lot of time stabilising an overclock and don't want to lose the settings.
Overclocking
All other areas of the BIOS are just as feature packed and the "Hardware Monitor" seen bottom right gives fairly accurate readouts of the motherboard voltages, temperatures and fan speeds as you would expect from an enthusiast board.
Overclocking
As you can see from above, the P5K actually managed to beat the maximum overclock we'd previously set using the E4300 chip on the P5B Premium board by ~50mhz (5mhz FSB). This certainly shows that the P35 Northbridge can offer the same (if not better) overclock potential as its predecessor the P965.
Dropping the multiplier down to 6x and increasing the Northbridge voltage to it's maximum of 1.70v allowed for some serious FSB speeds, with the P5K hitting a very impressive 520mhz. This is 40mhz higher than the maximum FSB obtainable on our P5B Premium board, and should certainly keep the overclocking crowd happy.
Great review Jim, article linked @ XS!
Quote
Nice review, god things are moving on so fast, soon DDR3 and heres me just upgraded and still on DDR1 lol.Quote
