Asus P6T Deluxe X58 OC Palm Edition Motherboard
Test Setup, Power Consumption & Overclocking
Published: 7th December 2008 | Source: ASUS | Price: £250.69 |
Test Setup
As promised, we will be pitching the Asus P6T deluxe and entry level i7 920 combo up against the best Skt 775 has to offer in the form of the Nvidia 790i Ultra and the range topping Intel QX9770. Obviously a direct comparison cannot be drawn due to the different motherboards, chipsets and not to mention triple channel memory but for the purposes of the review, the rigs will be run at there stock clocked levels. While I appreciate it is not a 'clock for clock' comparison, comparing clock for clock from one generation to another is fruitless as I think we all know what the outcome would be. With the QX having a 534mhz clockspeed advantage, the results may well be a little more even and should return a more balanced review.
To ensure that all reviews on Overclock3D are fair, consistent and unbiased, a standard set of hardware and software is used whenever possible during the comparative testing of two or more products. The configurations used in this review can be seen below:
During the testing of the setups above, special care was taken to ensure that the BIOS settings used matched whenever possible. A fresh install of Windows Vista was also used before the benchmarking began, with a full defrag of the hard drive once all the drivers and software were installed, preventing any possible performance issues due to leftover drivers from the previous motherboard installations. For the 3DMark and gaming tests a single card configuration was used.
To guarantee a broad range of results, the following benchmark utilities were used:
Power Consumption
Power consumption was measured at the socket using a plug-in mains power and energy monitor. Idle readings were taken after 5 minutes in Windows. Load readings were taken during a run of 3DMark Vantage.
Using a respectable Vcore of 1.4v, the remainder of BIOS voltage settings were left in their stock state to ensure equality throughout the testing. Obviously the two boards and CPU are different but these graphs show the overclocking potential of the CPU's and motherboards.
i7 Rig
CPU: Intel Nehalem i7 920 Skt1366 2.66GHz
Motherboard: Asus P6T Deluxe 'OC Palm'
Memory: 3x2GB Corsair Dominator DDR3 1600mhz @ 8-8-8-24
HD : Hitachi Deskstar 7k160 7200rpm 80GB
GPU: Nvidia GTX280
Graphics Drivers: GeForce 180.60
PSU: Gigabyte ODIN 1200w
790i Rig
CPU: Intel Yorkfield QX9770 skt 775 3.2Ghz
Motherboard: Nvidia 790i Ultra SLI
Memory: 2GB Patriot Viper @ 1600 8-8-8-24
HD: Hitachi Deskstar 7k160 7200rpm 80GB
GPU: Nvidia GTX280
PSU: Silverstone Strider 1000w
GPU: Nvidia GTX280
790i Rig
GPU: Nvidia GTX280
Synthetic CPU Test
• Sisoft Sandra 2009
• PassMark CPU test
• SuperPI 1m, 8m, 32m
Memory Test
• Everest 4.60
File Compression & Encoding
• 7-Zip File Compression
• River Past ViMark
Disk I/O Performance
• HDTach 3.0.4.0
3D / Rendering Benchmarks
• Cinebench 10
• 3DMark 05
• 3DMark 06
• 3DMark Vantage
3D Games
• Crysis
• Far Cry 2
• Company of Heroes
Overall System Performance
• PCMark Vantage
• PassMark CPU test
Memory Test
• Everest 4.60
• River Past ViMark
• HDTach 3.0.4.0
• Cinebench 10
• 3DMark 05
• 3DMark 06
• 3DMark Vantage
3D Games
• Crysis
• Far Cry 2
• Company of Heroes
• PCMark Vantage
Power Consumption
As you can see, the Skt775 based setup uses a lot more power at both idle and load. No additional software for power saving (such as the Asus EPU-6 engine) were used so the differences at idle could be even more given the right configuration. A few years use changing setups over to skt1366 and in particular the Asus P6T Deluxe, could see the system pay for itself!
OverclockingUsing a respectable Vcore of 1.4v, the remainder of BIOS voltage settings were left in their stock state to ensure equality throughout the testing. Obviously the two boards and CPU are different but these graphs show the overclocking potential of the CPU's and motherboards.
While it may look like the QX9770 overclocks a little better, the i7 920 starts of with a 534mhz deficit making it by far the better overclocker. All that was needed to overclock the i7 920 was a base clock increase to 200 mhz and the multiplier set to 20. With 1.4v on the Vcore, 4ghz was easily attained.
Let's take a look at how each setup compares in our suite of benchmarks with the settings reverted back to their stock state. Special consideration should be given to the fact that the QX9770 costs £1000+, while the i7 920 CPU used on the P6T Deluxe costs around a quarter of that. Bare in mind also that the i7 920 is the entry level CPU in the i7 range whereas the QX9770 is the range topper of skt775. It certainly makes for some interesting testing!
Hi!
Great review, mate!
I was very astonished, that the s775 sometimes can match or even overrun the new socket. Nevertheless the new platform is a great performer, but I don't think that the time has come to upgrade to it, maybe next year
. I would love to see how the new i7 performs against the new phenom 2 that are coming, because there are great things you hear about the overclocking performance of the new AMD's. Hope you will get a phenom 2 sample fast and compare these two.
And again, congrats for the great review.
Have a nice day.Quote
Great review, mate!
It`s doing a decent job. Nothing proud of a new socket tho.
I can see that the areas it does exel in are more than likely down to the tri-channel over dual channel.
I can't recommend them on this showing, but I still see this as part of the 1st round of mobos. The fact that it holds it`s own, with the exception of older graphic benchmarkers which dont mean much, means that whatever is to come should be that much better.
It`s a great review, like to see the Intel 4 Series ICH10R up against it tho as opposed to nVidia.Quote
Cheers for the feedback as ever guys.
The overclock was the max possible at the time of review. For whatever reason it wouldn't budge much over 200 but the rumours are that using a lower multi and higher Bclk helps, sadly this info came too late but rest assured, I will update when I get to test the mobo again as it looks like it could be the base for our new i7 test rigs.
We chose to pitch it against the NVidia chipset as it is the only chipset where we could have DDR3 aswell as having the capability to underclock the DDR3 to 1600mhz to best match the 1600 Corsair so comparisons could be made with dual vs triple channel ram. Intel chipsets would mean messing with the FSB and multi's of the QX9770 which inevitably would result in an unfair stock vs stock comparison of the CPU's.
It's always going to be hard reviewing a product with no legitimate comparative product. I could have copped out and just reviewed the P6T against itself, stock vs overclocked which is the norm but I thought everyone would have appreciated some results people they could relate to. Not many folk have the QX9770 granted, but it makes interesting reading having the top skt775 vs the entry i7, at least I hope it does
Keep your eyes peeled for the Gigabyte EX58-UD5 review coming very soon
.Quote
Cracking review...I'm still holding off for a whilst though...i'm hoping the phenom II's may push the price down...but its very impressive for a new socket utilising new tech...especially when you look at the entry/high end level comparison...it does show that the price is warranted...but lets hope AMD step in the ring a bit beefier then last time...Quote
Hopefully now that one is nailed down it'll be easier to review when more boards come.
Was that the maximum stable overclock you could get or were you just happy to get there and call it a day?Quote
