Asus P7P55-M P55 mATX Motherboard
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
PassMark is a popular benchmarking suite which test all aspect of PC hardware.The CPU test examines Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more. Each CPU test was performed a total of 5 times, with an average being calculated from the middle three results.
Results Analysis
 Both the MSI and Asus boards were perfectly matched throughout the CPU tests. The Asus board did however edge the results in both SuperPI and Passmark results.
Let's take a look at the memory benchmarks...
09-11-2009, 08:22:32
Rastalovich
Very decent, £90.
With it having better memory handling, on the surface, I was expecting it to be that much better than the msi in the following benchies. Didn't happen tho. These things tend to be illogical.
Full 4 ghz+ expectation on a small mobo too.
Weening away from the necessity of a full ATX for everyday+ builds, and I like it.
Good stuff.
See ASUS still like the rolly cardboard packing.Quote
18-11-2009, 04:24:42
hiiireaw
hi there!
I have read you posting. I find it so good. Thanks for you posting Quote
18-11-2009, 04:37:30
Mr. Smith
I'm with Rast - the future for me is small builds matx/mitx.
There are plenty of decent matx mobos capable of performing exactly like an atx mobo.
Nice reviewQuote
