Asus P7P55D EVO P55 Motherboard - Performance Revealed
Memory Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Everest is in many ways similar to Sisoft Sandra. Focusing mainly on software and hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining three.
Results Analysis
Sisoft Sandra and Lavalys Everest showed contrasting results here with Sandra placing the i5 setup behind both the i7 and AMD setups. Everest however placed the i5 between the two rigs. One has to bear in mind that the i5 and AM3 test beds were running at 1333MHz  with just 4GB of DDR3 though while the i7 was running 6GB at 1600MHz which will account for the huge difference in performance here. Never the less, if Everest is to be believed, the i5 setup is certainly capable.
Let's see how the boards perform in our Hard Drive benchmarks...
08-09-2009, 09:07:43
Hmmm. Needing some more details on the 6g sata situation as it unfolds.
According to the hdtach in the review, the controller used appears nothing to write home about.
Really nice low power consumption on idle.
8x - 8x won't make some people happy. Couldn't care less about that myself.
An opinion on the VIA HD sound would be interesting.
In all, being the launch of a new socket and all, not much impressing me here.
Roll on stable 6g and USB3.0 imo.
Rumor had it Gigabyte had sorted something out with the marvell and it would appear ASRock are supplying pcie cards for it.Quote
13-09-2009, 07:08:56
Yeah the PCIe cards are SATA 6G and they use the same controller. The problem is with PATA support so as the PCIe card does notsupport PATA the problem is null and void.
It won't be long before we see full 6G support and I agree, the ommision of USB 3.0 is disappointing. Let's hope the 2nd round of boards have these features fully supported.Quote
15-09-2009, 08:25:01
Nice review, but would like to know more detail about memory overclocking performance, such as the highest clock or required voltage, instead of only bandwidth testing.Quote
15-09-2009, 09:12:12
"and this is pure speculation my part" shouldnt there be an on in there?
how long till it gets released?Quote
15-09-2009, 14:50:37
Good spot - fixed.Quote
