ASUS P8-Z77V Pro Sandy Bridge Review
ASUS P8-Z77V Pro Review
The lesser of the Intel range has had a somewhat rocky period in its short life. We had the P55 LGA1156 based socket for a very short period of time, and that was quickly replaced by the P67 based LGA1155. That itself came with a few niggles which forced a B3 revision rerelease and within a small time scale we had the Z68 chipset which settled things down to a far more reasonable level. Indeed once Intel had got things worked out we really enjoyed some excellent performing motherboards and CPUs, all for a sensible price.
Now a year after the Z68 we're girding our loins for the 3rd Generation of Intel Socket 1155 processors and Intel have brought us the Z77 chipset in preparation.
Firstly what is new with the Z77? We have support for the 22nm 3rd Generation Intel Processors. Built in support for PCI Express 3.0, SATA 6Gbp/s and USB 3.0 are the main charms, and any time you can integrate connectivity options into the main chipset it is one less thing that you need to go hunting potentially conflicting drivers for. The other major change is the inclusion of the latest Lucid Virtu MVP technology which conceivably brings both the latest VSync improvements we've seen from the current flagship GPUs, alongside some performance improvements.
So the big question is, if you're a current owner of a Z68 does the Z77 supply enough new features to make it worthy of an upgrade, or are you better off awaiting the CPUs to go alongside them?
As always with ASUS motherboards you're getting a wealth of extra features. One of the most obvious choices is the use of an Intel Gigabit LAN which makes a big change from the standard Realtek solution we see. The other two standout features are things we looked at a while ago, namely the ASUS TPU and EPU dipswitches. The EPU helps improve your energy efficiency, and the TPU helps the AI overclocking.
CPUIntel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
ChipsetIntel® Z77
Memory4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
GraphicIntegrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU SupportSupports NVIDIA® Quad-GPU SLI™ Technology
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology
Expansion Slots2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1
2 x PCI
StorageIntel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology
ASMedia® PCIe SATA controller :
2 x SATA 6Gb/s port(s), navy blue
LANIntel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data NetworkWi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
AudioRealtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB PortsASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking FeaturesOverclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special FeaturesASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-Connector
Back I/O Ports1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
4 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
AccessoriesUser's manual
ASUS Q-Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
08-04-2012, 05:56:59
nice review, as everQuote
08-04-2012, 06:27:26
What he said!Quote
08-04-2012, 06:30:47
Great review, enjoyed it. So those with a P67 board could benefit with this as an upgrade? Are we getting an X79 review soon also? Quote
08-04-2012, 06:59:04
Nice looking board, i'm looking forward to the GD65 review (if there is one) because i'll be grabbing one so I can finally get rid of this H61 board i'm using and get back to doing some overclocking
Also looking forward to seeing if these boards give any benefit over SB with an IB CPU, from what I have read Z77 boards are better for overclocking IB at lower voltages than P67 and Z68.Quote
08-04-2012, 08:04:05
Very good reveiw Quote
