ASUS P8-Z77V Pro Sandy Bridge Review
PC Mark
Published: 8th April 2012 | Source: ASUS | Price: £169 |
PC Mark Vantage
Naturally with the F80 moved from cache to the main drive the increase in PC Mark is visible. What stands out is how the overclock of our CPU is carried through on the P8-Z77V Pro to improvements in every result. A 40% overclock gives around a ten percent increase. Good stuff.
PC Mark 7
The latest version of the PC Mark test suite is obviously better designed for the modern technologies available to us and it's clear it took advantage of the IRST when the F80 was used as a cache drive, because as the main drive it only has a slight improvement. Even still the stock results on the P8-Z77V Pro are particularly good.
Also looking forward to seeing if these boards give any benefit over SB with an IB CPU, from what I have read Z77 boards are better for overclocking IB at lower voltages than P67 and Z68.Quote
