ASUS ProArt Z690 Creator WiFi review
Test Setup
32GB Corsair Dominator Platinum DDR5
Intel Core i9-12900K
Windows 11 64bit
Sabrent 4TB Rocket Plus
Nvidia RTX 2080Ti
Corsair AX1600i
Corsair H150i with Noctua 3000 RPM fans
Clock Speeds
Like all ASUS products the ProArt Creator can overclock your processor should you want to extract a little more from it, but it’s worth bearing in mind that the Intel Core i9 12900K is extremely warm and so only those with some beefy cooling options need apply.
