ASUS ROG Strix X470-F Gaming Review
Published: 19th April 2018 | Source: ASUS | Price: |
We can breathe a small sigh of relief at this point, knowing that we've finally reached the end of our lengthy set of reviews to accompany the launch of the 2nd Generation of AMD Ryzen CPUs and their X470 chipset. It's been a rollercoaster. Hopefully you have enjoyed reading about them all as much as we've enjoyed bringing them to you.
Probably the biggest take away we have from our time with the X470 and Ryzen 2 is how consistent it is in every possible set up. Whether running at stock on an affordable motherboard or running balls to the wall on a seriously high-end flagship offering, the scores remain incredibly tightly grouped, which if nothing else frees you up to make a choice based upon which one you like the most or can afford rather than being forced to pick based upon raw output.
The ASUS ROG Strix X470-F Gaming was the final motherboard we looked at and to a reasonable degree we think that - unintentionally - we've saved the best for last. The MSI M7 might outperform it at the high end, the Gigabyte Gaming 7 might be flashier, the Crosshair VII has more connectivity options, but the Strix has monstrously good stock performance and damn fine overclocking performance to boot. We often see motherboards that overclock well being slightly soft at stock, because the design is intended to be pushed hard, and good stock performance doesn't always equate to high overclocking because normally that means that the motherboard is already slightly overclocked to gain a little bit at stock. The Strix seems to do both of these things well. Clearly the stock performance is outstanding, regularly finding itself not only at the top of the stock group of motherboards in our graph but in the thick of the action with the overclocked setups too.
Aesthetically the Strix is neutral enough to find a place in any system that doesn't rely upon a white PCB. It has, if we have to be extremely nit-picky, perhaps not quite the wow factor we were hoping for from the gaming arm of the ASUS family. Certainly looking at how much the Gigabyte brings to the party, and what the Strix range has had under its umbrella before, we were hoping for a little more than just the slogan daubed chipset heatsink and a little bit of RGB lighting at the top left. As we say though, this is very much us nit-picking an otherwise excellent product.
Whether you plan to run at stock or want to delve into the BIOS and overclock you'll be pleased with the performance you can achieve from the ASUS ROG Strix X470-F Gaming. If it was any more well rounded it could double up as a cannon ball.
Discuss your thoughts about the ASUS ROG X470-F Gaming in our OC3D Forums.
you would think asus gives AMD a bit more love after the ryzen success.
yet no matx boards. ![]() and only high priced ITX boards. i don´t buy a 200 euro ITX board for a small mailserver / FTP etc. |
MATX is dying and ITX really hasn't caught on as much as people who liked it thought it would. It's quite easy to decipher that big company who knows what sells and yet is not making MATX boards. What is the reason? simple - they don't sell. So they are going to make what does sell, and in this case full ATX boards.Quote
I dont think you should buy Ryzen+ for that either tbhQuote
If we are talking 2600, 2600X, 2700 and 2700X its retardidly over spec'dQuote
yet no matx boards.
i don´t buy a 200 euro ITX board for a small mailserver / FTP etc.Quote
