ASUS ROG X370 Crosshair VI Extreme Review
Geekbench, Realbench, Userbench
ASUS X370 Crosshair VI Extreme Review
If you've been following along so far then you'll know what to expect from our CPU intensive benchmarks in Geekbench and Userbench where the Crosshair Extreme continues to dominate proceedings.
Before our Ryzen retest something has definitely changed with either drivers or a Windows update as now Realbench is scoring very poorly. Unfortunately it's nothing we can fix because we can't rollback to older things even if we knew what had caused the problem. Perhaps we might need to drop it, or await a fix.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Next»
23-07-2017, 17:59:13
Avet
Nice review Tom. This one really is proper enthusiast board with all the sweet thingys on it.
I am actually not a fan of horizontal 24-pin socket. Because when it is horizontal you get a massive peace of black plastics (24-pin + cable), and your cables go 3cm straight into the grommet. With classical (vertical) one you get to use cable combs, and make that nice curve with cables, and show them off. Let's face it... what is the point on blowing serious money on custom cables when you get to show 3cm of them, and instead you get 10x10cm block of plastic instead?Quote
23-07-2017, 18:19:13
Wraith
Do you know how long I've waited for someone other than EVGA to do a 45 degree 24 pin! I love it and wish it was on all boards or at least a 45 degree adapter for those of us who don't want to see cables this is epic, I'm now waiting for the day all IOs around the edge of Motherboards are angled.Quote
23-07-2017, 18:42:15
BigDaddyKong
Thanks for the review.
I am curious to what voltage and LLC to get the 4.1ghz you tested on.
Also, did you make any adjustment to the BGS and BSWalt?Quote
23-07-2017, 20:01:37
Bratticuss
Very good review as always.
Looks like I have found my next PC upgrade.
Haven't done a AMD build for over 3 years. Looks like a Ryzen year.Quote
23-07-2017, 21:30:18
Avet
Every other connection angled yes, that is epic, but for me, 24-pin and 8-pin no. And please someone put power cables on GPUs on the side.Quote
