Asus Sabertooth 55i TUF P55 Motherboard
Gaming Performance
Crysis is without doubt one of the most visually stunning and hardware-challenging games to date. By using CrysisBench - a tool developed independently of Crysis - we performed a total of 5 timedemo benchmarks using a GPU-intensive pre-recorded demo. To ensure the most accurate results, the highest and lowest benchmark scores were then removed and an average calculated from the remaining three.
Call of Duty 4 is a stunning DirectX 9.0c based game that really looks awesome and has a very full feature set. With lots of advanced lighting, smoke and water effects, the game has excellent explosions along with fast game play. Using the in-built Call Of Duty features, a 10-minute long game play demo was recorded and replayed on each of the GPU's using the /timedemo command a total of 5 times. The highest and lowest FPS results were then removed, with an average being calculated from the remaining 3 results.
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning "world", "earth" or "living" in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Results Analysis
The Sabertooth is starting to make a habit of winning and the gaming suite of benchmarks was no different with the Asus mainboard once more proving it's worth, albeit by a slight margin.
Let's take a look at it's overall performance with a run of PCMark Vantage 64bit...
18-11-2009, 17:09:45
Mr. Smith
This would suit a cool military buildQuote
12-02-2010, 08:24:27
Skiddywinks
Getting one of these as a prize off Asus. Looking top pick up an i5-750 and see what I can do!Quote
12-02-2010, 08:32:01
cl0ck_ed
Sounds gd mate. Get your results up on this forum, I'd like to see how well you do. Quote
02-03-2010, 14:28:29
miloud06
It's not the motherboard which limits the coefficient to 22x but the CPU :
core i5 750 is blocked to 20x
core i7 860 is blocked to 21x
core i7 870 is blocked to 22xQuote
02-03-2010, 20:03:09
mayhem
That is not a nice looking MBQuote
