Asus Sabertooth 55i TUF P55 Motherboard
CPU Performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
SuperPI is the benchmark of choice for many overclockers. It's lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
PassMark is a popular benchmarking suite which test all aspect of PC hardware.The CPU test examines Mathematical operations, compression, encryption, SSE, 3DNow! instructions and more. Each CPU test was performed a total of 5 times, with an average being calculated from the middle three results.
Results Analysis
 The Sabertooth gets off to a flying start coming top in all of the CPU benchmarks run beating our previous best motherboard, the MSI P55-GD80 by a clear margin. One has to consider though that the CPU was running 14MHz faster than stock despite being set to 200x20 which may have had a little bearing on the results.
Let's take a look at the memory benchmarks...
18-11-2009, 17:09:45
Mr. Smith
This would suit a cool military buildQuote
12-02-2010, 08:24:27
Skiddywinks
Getting one of these as a prize off Asus. Looking top pick up an i5-750 and see what I can do!Quote
12-02-2010, 08:32:01
cl0ck_ed
Sounds gd mate. Get your results up on this forum, I'd like to see how well you do. Quote
02-03-2010, 14:28:29
miloud06
It's not the motherboard which limits the coefficient to 22x but the CPU :
core i5 750 is blocked to 20x
core i7 860 is blocked to 21x
core i7 870 is blocked to 22xQuote
02-03-2010, 20:03:09
mayhem
That is not a nice looking MBQuote
