Asus Sabertooth 55i TUF P55 Motherboard
Multimedia & Encoding performance
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
7-Zip is an open source Winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
Results Observations
Multimedia and encoding is clearly one of the Sabertooths strong points, taking advantage of its exceptional CPU and memory performance. While all the motherboards on test appeared to perform equally, the Sabertooth had the slight edge, winning out in every benchmark run.
Let's move on to our synthetic 3D Benchmarks...
18-11-2009, 17:09:45
Mr. Smith
This would suit a cool military buildQuote
12-02-2010, 08:24:27
Skiddywinks
Getting one of these as a prize off Asus. Looking top pick up an i5-750 and see what I can do!Quote
12-02-2010, 08:32:01
cl0ck_ed
Sounds gd mate. Get your results up on this forum, I'd like to see how well you do. Quote
02-03-2010, 14:28:29
miloud06
It's not the motherboard which limits the coefficient to 22x but the CPU :
core i5 750 is blocked to 20x
core i7 860 is blocked to 21x
core i7 870 is blocked to 22xQuote
02-03-2010, 20:03:09
mayhem
That is not a nice looking MBQuote
