ASUS TUF B550M-Plus WiFi Review
Sony Vegas
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
Sony Vegas
Such is the affordability and performance capabilities of the Sony Vegas platform it has rapidly grown in the market to be a genuine contender for the content creation weapon of choice. We use a complex 4K file to test the rendering speed.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
