ASUS TUF B550M-Plus WiFi Review
Geekbench
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
Geekbench
Geekbench tests the single and multi-threaded performance of your system and is a good indicator of any weak spots, particularly if you’re overclocking. It's also a good demonstration of how well the AMD single threaded boost performance works at stock.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
