ASUS TUF B550M-Plus WiFi Review
PCMark 10
PCMARK 10
The umpteen versions of PCMARK used a selection of applications to test your systems utility as an overall setup for work. Each version came with its own foibles wherein it has overly weighted certain aspects of the tests when calculating the final score, but it was still useful when comparing like for like. The latest PCMARK 10 is perfectly suited to take advantage of all the latest optimisations and is much cleaner in its score calculations.
ASUS TUF B550M-Plus WiFi PCMark 10
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
29-06-2020, 16:24:45
gunnarre
One correction on page 2 (up close): "Between the two PCI Express slots - the uppermost armoured one being PCIe 4.0 whilst the black one is PCIe 3.0 - we have the heatspreader for the PCIe 4.0 M.2 drive that will bring you blistering transfer rates."
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
31-07-2020, 00:36:16
WinWiz
Overclocking micron rev E ddr4 needs low dram termination voltage.
What voltage range is available on this board?Quote
