ASUS TUF B550M-Plus WiFi Review
Gaming
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
Gaming
Lastly our gaming benchmarks are the real world application of the results we’ve seen on the preceding two pages. Far Cry 5 is a good all-rounder; Metro Exodus stretches your systems capabilities; The Division 2 utilises lots of the latest technological advances whilst Total War : Three Kingdoms is as CPU intensive as almost any game around.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
