ASUS TUF B550M-Plus WiFi Review
Test Setup and Overclocking
Test Setup
As well as the B550 motherboards we're also including our X570 motherboards in our graphs today, just to demonstrate how little the 'lesser' AMD Chipset is giving up compared to its bigger brother. Perfect if you're on a tight budget.
AMD Ryzen 9 3900X
G.Skill Trident Z 3600 MHz
Corsair Vengeance RGB 4600 MHz
Corsair MP500 M.2 - OS Drive
Aorus PCIE4 NVME - Storage Speed Tests
Nvidia RTX 2080Ti
Corsair HX1000i
Corsair H150i
Corsair ML Fans
Overclocking
So far we've had some pretty high end motherboards to work with and they've all squeezed 4.4 GHz from our test Ryzen 9 3900X. The Strix-F and MSI Mortar topped out at 4.35 GHz and the TUF Plus continues that trend of the more affordable options not quite getting everything from our CPU, even if 50 MHz a thread is hardly a massive disparity. Our results will show how much, so let's get down to some benchmarking.
ASUS TUF B550M-Plus WiFi Overclocking Ryzen 9 3900X
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
29-06-2020, 16:24:45
gunnarre
One correction on page 2 (up close): "Between the two PCI Express slots - the uppermost armoured one being PCIe 4.0 whilst the black one is PCIe 3.0 - we have the heatspreader for the PCIe 4.0 M.2 drive that will bring you blistering transfer rates."
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
31-07-2020, 00:36:16
WinWiz
Overclocking micron rev E ddr4 needs low dram termination voltage.
What voltage range is available on this board?Quote
