ASUS TUF B550M-Plus WiFi Review
SiSoft Sandra
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
SiSoft Sandra
Sandra performs a similar function to AIDA64, but it tests it in a different manner which gives us an excellent overview of the whole setup and how well rounded it is. The tests take longer than the AIDA64 ones, but that just makes them more likely to trip up a poorly implemented overclock, or weed out any hidden depths.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
