ASUS TUF B550M-Plus WiFi Review
Blender
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
Blender
Blender is a free rendering program that is supremely powerful. If you ever find yourself wondering why 3D elements take so long to create in films or games, a moment with Blender will show how much raw horsepower you need to perform even the simplest tasks. We have our own custom blend render available in both 1080P and 4K. The 4K one will bring even the hardiest setup to its knees.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
