ASUS TUF B550M-Plus WiFi Review
Cinebench R20
Published: 16th June 2020 | Source: ASUS | Price: £179.99 |
Cinebench R20
The latest version of Maxon’s rendering engine tests both single core performance as well as the multi-threaded option, dispensing with the OpenGL rendering test we had in the earlier version. We have graphs sorted by both the full multithreaded score as well as single threaded result.
What voltage range is available on this board?Quote
That is the PCIe 3.0 M.2 slot. The PCIe 4.0 M.2 slot is the one closest to the CPU and does not come with a heat spreader, presumably because Asus expects that the PCIe 4.0 SSDs will come with their own heat spreaders. Corsair - which is part of the "TUF alliance" with Asus - deliver their MP600 series PCIe 4.0 M.2 SSDs with integrated heat spreaders. Seagate's ZP500 does not come with a heat spreader, so you'd probably have to buy one if you plan to use that SSD on this motherboard.
Gigabyte's AORUS PCIe 4.0 M.2 SSD also comes with its own heat spreader, which means you'll have spare ones, as Gigabyte's B550 motherboards come with a heat spreader.Quote
