ASUS TUF Gaming X570 Plus WiFi Review
PCMARK 10
ASUS TUF Gaming X570-Plus Wi-Fi Review
PCMARK 10
The umpteen versions of PCMARK used a selection of applications to test your systems utility as an overall setup for work. Each version came with its own foibles wherein it has overly weighted certain aspects of the tests when calculating the final score, but it was still useful when comparing like for like. The latest PCMARK 10 is perfectly suited to take advantage of all the latest optimisations and is much cleaner in its score calculations.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
27-10-2019, 13:20:26
Dicehunter
I miss the original Sabertooth line of TUF boards with the armour, Yeah it was only for show but mixed with a full cover metal backplate it gave the board a really cool look and feel, These new TUF boards since Z170, Horrible looking, Onwards all look like high end Fisherprice toys.Quote
28-10-2019, 09:15:40
Warchild
Actually I tested the P67 Armor with and without the armor long ago. If you had a CPU fan that blew down on the CPU as opposed to perpendicular, the temp drop on the VRM, and chipsets with the armor was a difference of 10C!!!!
Mainly because you could close the vents and generate a strong air flow underneath it. I think the Z77/97 also had this design, but then it became less effective. And now.. as you say, just for show.Quote
