ASUS TUF Gaming X570 Plus WiFi Review
CPU Temperatures
ASUS TUF Gaming X570-Plus Wi-Fi Review
CPU Temperatures
Although our overclocking efforts always try and push the CPU to its absolute thermal limits and thus this graph isn't all that useful as far as the overclocking results are concerned, it does at least demonstrate how efficient the motherboard is and the kind of heat generated you can expect. When we're limited by the abilities of the CPU itself it also shows how much/little voltage is needed to hit our silicon limits.
ASUS TUF Gaming X570-Plus Wi-Fi Temperatures
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Next»
27-10-2019, 13:20:26
Dicehunter
I miss the original Sabertooth line of TUF boards with the armour, Yeah it was only for show but mixed with a full cover metal backplate it gave the board a really cool look and feel, These new TUF boards since Z170, Horrible looking, Onwards all look like high end Fisherprice toys.Quote
28-10-2019, 09:15:40
Warchild
Actually I tested the P67 Armor with and without the armor long ago. If you had a CPU fan that blew down on the CPU as opposed to perpendicular, the temp drop on the VRM, and chipsets with the armor was a difference of 10C!!!!
Mainly because you could close the vents and generate a strong air flow underneath it. I think the Z77/97 also had this design, but then it became less effective. And now.. as you say, just for show.Quote
