ASUS TUF X470-Plus Review
Up Close
Up Close
The TUF range has generally gone for a utilitarian aesthetic and the X470 Plus is no exception. The packaging is definitely of the "no fuss" variety with the model name dominating proceedings.
Out of the box the first thing that grabs your attention is the TUF logo which wouldn't look out of place on a 1970s concert poster. Whilst the X470 hasn't got the TUF Armor it does have another entry in the ASUS printed PCB range, something that helps break up the visuals better than a plain black PCB might.
At the top end of the motherboard is the familiar AM4 socket alongside the four DIMM slots for the up-to 3200MHz DDR4 that the TUF supports. We're so used to seeing massive rows of chokes that the relatively few on the TUF came as a small surprise, but it means that there is much more room available around the CPU socket, something that will be of interest to the heavy overclocking brigade.
It seems curious for a motherboard labelled TUF to not come with fully reinforced slots for either the PCI Express cards nor the DDR4 modules. We are pleased to see that ASUS have included two full size M.2 ports though, perfect to maximise your storage speeds and capacity.
The decision to utilise our hated vertical SATA ports doesn't fill us with love for the TUF either. There is something about the combination that just looks a little cheap. Given how impressive older models in the TUF range were, and how much we loved them, we have to say that this particular design doesn't remotely put a tilt in our kilt.
One thing that the TUF X470-Plus doesn't lack for is fan headers. With dedicated fan/AIO headers at the side of the TUF and two at the top by the CPU socket you can be sure that there is enough places available on the PCB to let you place your cooling in the most suitable spot.
There is just the one RGB LED strip header on the TUF, above the ATX 24 pin input. Anybody else feel that the random piece of design in the middle of the DIMM slots looks like someone in a crash helmet twerking or is our pareidolia acting up again?
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Next»
11-07-2018, 15:37:27
WYP
... It always annoys me when motherboards ship without full voltage control. I don't like using voltage offsets, they differ far too much from board to board and don't offer the kind of control that I would expect when overclocking. I would have expected more from an X470 motherboard.Quote
11-07-2018, 16:34:07
Bartacus
Damn, Asus appears to be slipping. I'm still not happy with my CH6 Hero, and this looks even worse. Eeek!Quote
12-07-2018, 09:26:10
Gothmoth
why not? i have two of them and they run flawless 24/7.Quote
12-07-2018, 11:44:10
Bartacus
Lucky you. I can't even shut off the damn motherboard LEDs without cutting power to the system (and yes the option IS set in the bios). I've also had to revert to stock due to stability issues. Not impressed.Quote
06-02-2019, 15:08:14
justjayhere
I get so tired of reading reviews where they want to compare hardware to the flagship hardware when most folk are not going to notice a difference between any of these MB's with the same hardware build, and Clearly the only ones slipping here is this reviewer not Asus. I personally have this MB in my current build with a liquid-cooled Ryzen 2600x and you can most certainly overclock this board in the bios... you can also save OC profiles etc. The reason I went with the ASUS TUF X470-PLUS GAMING is more for the "TUF" Over-built Protection. I live is an area that is hot and humid in the summer or cold and electrostatic-dry in the winter. Plus everyone knows that Precision Boost is the way to go with a Ryzen CPU anyway. And if you want to OC a Ryzen on-the-fly... just use Ryzen Master software.Quote
