ASUS X299 Prime Deluxe II Review
Published: 2nd January 2019 | Source: ASUS | Price: |
The ASUS Prime has long been one of the most solid motherboards around and indeed formed the backbone of our testing of newly launched CPUs.
Naturally technology moves at a blistering pace, and you can't call a motherboard a Prime model without ensuring it keeps up with the ever changing world in which we live. ASUS have therefore gone back to the drawing board and added a host of features to the Prime to ensure that it remains on the cutting edge of hardware options.
Whilst the Z390 and 9th Generation Intel Core CPUs might be grabbing all the headlines at the moment, the X299 range is still the premium choice with some of the best processors on earth supported by the LGA 2066 socket. Is the Prime Deluxe II worthy of your investment? Time to find out.
The original Prime was hardly lacking in features, but the new Prime Deluxe II has seen a wealth of additions. As well as all the elements you would expect to find on a fully-featured X299 motherboard, the Deluxe II now is equipped with an Aquantia 5G LAN socket on board, Intel's latest 9260 MU-MIMO 802.11ac Wireless networking and the best Thunderbolt 3 implementation we've seen yet. Additionally ASUS own technologies have been updated with the addition of OptiMem II allowing your DDR4 to run at up to 4266 MHz; three M.2 slots with redesigned heatsinks to better utilise your airflow to keep your transfer speeds in the stratosphere, The LiveDash OLED display, and a fan extension card to help keep all your components cool. With front and rear USB 3.1 alongside three PCI Express 3.0 slots the Prime Deluxe II caters to all your requirements.
Disclaimer: This is a personal rant. I was looking forward to this board because i like ASUS, and i like Deluxe boards. (I am rocking Z97 Deluxe now) And this could have bean the perfect board for my next system in the near future (possibly). I need Thunderbolt and I was waiting for this board's release. I would be happy if i am wrong and this sin't the case.
Amazing looking board, but it has a catastrophic flaw. I read through documentation and it is not specified anywhere, but if you look at the lane distribution Thunderbolt 3 is connected via PCH. Also there is no block diagram in the manual. Hmm... Intel platforms don't have 24 PCH lanes, they have 4. Because PCH is connected to CPU via DMI 3.0 link which is PCI-E 3 x4. So PCH is basically a PLX chip that governs the traffic. It is enough to put 1 NVME drive on PCH slot, with couple of HDDs, with all the regular traffic (USBs, Network, etc.) and DMI is clogged up. Where do you find the bandwidth then for 2 Thunderbolt 3 pots? You can't run 1 at full speed via PCH. They could have done it with CPU lanes. They have done it before. Previous Deluxe boards had crazy lane distribution. And you could connect anything. Rampage VI Extreme has good lane distribution. You could run Dimm.2 drives from PCH or from CPU lanes. If you run it form CPU last PCI-E slot is reduced to x4 from x8. If you run them from PCH, PCI-E x4 slot is disabled. Brilliant. And what was wrong with add-in board on previous Deluxe motherboards? If you need it use it, and you have proper CPU x4 lanes. If you don't, then leave it in the box. This way if you need Thunderbolt 3 you can't use it. And you can't put add-in board. And it says it supports it. Just a cheep marketing trick to say that board has native support for Thunderbolt 3. If you need Thunderbolt 3 connectivity don't bother with this board. It doesn't support it. Go with any other board that has Thunderbolt 3 support via add-in card. Back to the drawing board with this one ASUS. |
Also my rant is - Shame that readers have to pick up on stuff like this, this is the stuff reviewers should be highlighting.
ASUS X299 Prime Deluxe II = Crap Board = Don't buy itQuote
ASUS X299 Prime Deluxe II = Crap Board = Don't buy it |
not to step on anyones foot here but....
reviewing today means benchmarking a few dozen apps and games. something that is completely useless for me. i don´t care about 5% performance difference.
it´s nice to know that a board is as fast as to be expected.... but that´s it.
the flaws a board has you will most likely not find on vlogs or "review" websites.
they install windows and run a few tests. then they focus on the next content to create. lately some folks focus on VRM temps and but that is as deep as it gets.
i have seen so many boards praised only to find obvious issues in real life.
example... a board has 6 SATA ports and not a single website (out of 5) mentions that 2 of them need to be disabled when you enable another feature.
it is a chipset (pci lane) limitation but all you read is "the board has 6 SATA ports".... yeah well i can see that. i can read a spec list and look at a photo.Quote
example... a board has 6 SATA ports and not a single website (out of 5) mentions that 2 of them need to be disabled when you enable another feature. it is a chipset (pci lane) limitation but all you read is "the board has 6 SATA ports".... yeah well i can see that. i can read a spec list and look at a photo. |
Those kind of details get covered in the initial cpu/platform review - no need to bring it up on every single board.
As for the Thunderbolt - I have no way to accurately test it (I dont have one TB enabled screen let alone 2 or 3) and to say about the bandwidth Id need to say why its required and what the impact has been - not might be.
Sometimes you just have to do the best that you can do with what you have available.Quote
Back to the drawing board with this one ASUS.Quote
