ASUS Z270I Strix ITX Motherboard Review
Passmark
ASUS Z270I Strix ITX Review
Passmark
Passmark 9 tests your system differently to PC Mark and yet our results are very much the same, showing what a high quality option the Z270I is.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Next»
07-02-2017, 07:00:11
Dawelio
Really nice article and I'm more happy with my purchase of this motherboard, that I got yesterday, after reading this
I went away from ITX previously, due to the limiting 16GB RAM. Although, this can have 32GB, wich is a win for me
Just a quick, probably silly question, but when you went to those 4000+ memory speeds, did you just go into the BIOS and then set it to 4000, saved and restarted? Or did you do anything else to make it run stable at that speed?.Quote
07-02-2017, 07:01:26
tinytomlogan
Just a quick, probably silly question, but when you went to those 4000+ memory speeds, did you just go into the BIOS and then sit it to 4000, saved and restarted? Or did you do anything else to make it run stable at that speed?.
It will work with just XMP but Id advise you working the VCCIO and System Agent volts down as low as you can one at a timeQuote
07-02-2017, 07:03:04
Dawelio
Ahh okay, cheers. My memory is only 3000MHz though, but will check it out and do Quote
07-02-2017, 07:07:22
tinytomlogan
You wont be able to just expect that to hit 4K. I have seperate 3866, 4000, 4133 and 4266 kits I just use for XMP testing....Quote
07-02-2017, 07:09:17
Dawelio
Nahh dude, as long as I can manage to get it to actually run at their advertised 3000MHz speed stable, I'm all good Quote
